Hello NXP
I'm working on a camera related project [ Using C Programming Only ] for that i need your help.
1] to capture an image and record a video and then encode the same.
2] after that i need to downscale that image and send to TV [ Host ].
So, to execute the above things could you please share some methods / tools / libraries / techniques to do the same.
Q1 : If i could use GStreamer, then i want to know the difference between how to capture / record and encode using GStreamer plugins ?? [ Difference between record / capture and encode via GStreamer ]
Q2 : and for downscaling could i use OpenCV [ for C programming only ] ??
If yes, then send me PDF / tools / libraries / methods realted to OpenCV
Nikhil
Solved! Go to Solution.
Hi nikhil29
what processor used in the case. One can start with Chapter 6 Video
Chapter 10 Unit Tests
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_5.4.24_2.1.0
Gstreamer examples in sect.7.3 Multimedia use cases i.MX Linux User’s Guide
No matter how long you have played, you will still not be able to accurately estimate the altitude of each takeoff. Therefore, any water pipe will be an extremely difficult challenge. Flappy Bird
Dark Dale is a Digital Marketer and blogger who ensures that a consistent important message is delivered to the user. He is detail-oriented and talented, allowing him to incorporate his digital & blogging skills with his vision to identify user needs and provide the best information to his readers. <a href=https://www.gotoassignmenthelp.com/blog/highly-effective-assignment-help-services-for-students/
Thanks for one marvelous posting! I enjoyed reading it; you are a great author.I will make sure to bookmark your blog and may come back someday. I want to encourage that you continue your great posts, have a nice weekend!
Hi nikhil29
Thanks igor for your time
I'm using i.MX 8M Plus as a processor.
1) could you please ellaborate diff. between record/capture and encoding via GStreamer
2) what about OpneCV ??
nikhil
Hi nikhil29
that processor is not supported yet, it is "Preproduction" part.
It will be supported after public launch.
Ok igor, thankuu for your time
Nikhil
