Hello, I want to do some customization in PN7150 using its code memory. Please let me is it possible or not & If so then how to do it, Because I found there are only I2C interfaces available to be connected to the Device Host.
That is not possible. The PN7150 is a NFC controller with integrated firmware. This IC is fully user controllable by the firmware interface, which cannot be changed.
Ricardo
