Hello.
TJA1051T is high-speed CAN FD Transceiver. According to the datasheet, It can support up to 5Mbit/sec data rate. I am wondering if there is any problem with the TJA1051T supporting Low speed CAN communication as well (100Kbit, 500Kbit).
Thank you.
Solved! Go to Solution.
Hello Wayne,
The relevant parameter is the TXD dominant time-out time:
Tomas
Hello Wayne,
Tomas
