Hello all,
This is a question about LS2088a. I am posting here since I could not find a forum specifically related to it. Please let me know if there is such a forum.
I am debugging an issue relating to EDAC errors and need to experiment disabling the EDAC.
In the build config file there are two flags.
CONFIG_EDAC=y
CONFIG_EDAC_LAYERSCAPE=y
Can you please tell me what is the difference between those two flags? Which one do I need to disable in order to disable EDAC for LS2088a?
thanks and best regards
Madhu
