In CLRC66303HNE, is the TVSS pin and VSS pin connected internally in the IC?
As displayed in the Eval board, the layer 2 is required to be a full ground plane even under the matching circuit.
Thanks.
Danz
Solved! Go to Solution.
Hello @Danz1
Thanks for contacting us and interested in the NXP products.
The two pins are not connected internal. VSS is ground and heat sink connection, TVSS is transmitter ground and supplies the output stage of TX1, TX2. According to the development board these two pins can be connected. That is to say the system can be working refer to the same ground.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002s3UlvAAE
The portal allows access to the full details of the case, including the previous communication.
Kelly
Technical Support
NXP Semiconductor
Hello @Danz1
Kelly
Technical Support
NXP Semiconductor
