CLEV6603B EvalBoard Antenna
Search instead for
I'm working with the CLEV6603B EvalBoard. I have the schematic of the board incl. the big Antenna 65mmx65mm.
Now I need the schematic (matching components) of the small antenna 30mmx50mm.
Could you provide me with this schematic and layout data?
Hi ,
Hope you are doing great, for this please find the following image
I could not found more information about this small board. hope this is helpful.
Jonathan
Spoiler
Thank you very much. It is exactly what I needed.
I decided to change the NFC-controller. I’m working now with the PN5180. Could you provide me with the matching for the 30x50mm antenna of the evalboard PNEV5180B as well?
This should be slightly different from CLEV6603B.
