CBTL01023 2:1 MUX P/N swap
peternemeth
Could you please confirm that it is possible to swap the P and N lines of the device to achieve better layout?
(Use the A_P, B_P, C_P pins for the N signals and use the A_N, B_N, C_N pins for the P signals.)
lisettelozano
Hello Peter,
You should have no issues by swapping the P and N lines, just make sure to not mix the signals and take in consideration the limiting values.
Paulina
lisettelozano
Hello Peter,
Paulina
peternemeth
Thank you very much for your help!
Peter
