The customer received the original material as shown below, and the label model is TJA1145AT/FD/0,
This is inconsistent with the TJA1145AT/FD/0Z order item placed in the system.The customer wants to know the difference between the description of the suffix 0 and 0Z written documents,As well as the suffix about the different information reference of the packaging and testing plant,Thanks!
Solved! Go to Solution.
Hello Louis,
TJA1145AT/FD/0 that is visible on the label indicates the product type.
TJA1145AT/FD/0Z is orderable part number of that product type in Z = 431 = Packing: REEL-Reel 13" Q1/T1 in Sulfur Barrier Bag
https://www.nxp.com/docs/en/supporting-information/Packing_Letter_code.pdf
Please refer to product page and the related datasheet:
https://www.nxp.com/part/TJA1145AT#/
https://www.nxp.com/docs/en/data-sheet/TJA1145A.pdf
Locations can be different. If any doubts please double check the locations details related to the particular customer's order with your CSR representative inside NXP.
Have a nice day. Best regards
Pavla
Hello Louis,
Pavla
