C daemon execute system() in Android
1,678 次查看
ilanganor
I have compiled a C daemon that runs on Android (Android 6)
-rwxrwxrwx root     root       715940 2017-09-21 14:51 server.o
the daemon runs fine, and responds to requests from clients. However, I would like to initiate a system() call from the daemon, for example:
system("mkdir /data/test/");
this fails (any system() call I made failed, reference on Linux, same code different Makefile works fine). The Android is rooted. Please advice how to perform system() commands from C daemon on Android.
Original Attachment has been moved to: server_listner-master.zip
标记 (1)
1,496 次查看
diegoadrian
Can you please, take a look at the bellow blog:
system call for makefile
Probably, this can solve your problem.
Diego.
