Just reading through Datasheet document number: AFSC5G35D37
There are 6 bias supplies in the datasheet for the board, but only three are listed in the functional test in the datasheet. I was hoping to clarify what the nominal bias levels should be for: VDP, VGP1, VGP2, VGC1, VGC2, VDC for the test case presented in the datasheet
Thanks in advance.
Please, refer to page 5 of the board description PDF:
Pavel
NXP TIC
