Hi everyone,
Is there a list on Freescale's website that shows the changes (fixes, etc.) of the rev 1.9.8 of Beekit comparing with the rev 1.9.7 ?
When you install Beekit, in the program files/Freescale/ directory you will find the release note for the current Beekit. In this document there is a section "Changes Since BeeKit x.x.x Release" This section tells you about the changes they have done in this current verion as compared to the version just previous to it.
I use Beekit verion 1.9.6 and the release note for this version has the section "Changes Since BeeKit 1.9.5 Release" which tells me the changelog for this version.
Saurabh.
if somebody of the developer team reads this: I think it would be highly appreciated to see the change notes BEFORE having to install BeeKit in order to decide if the changes are worth it. Thank You!
