Can you recommend a microprocessor not a microcontroller for an electric vehicle applications? I need to design an ECU containing microprocessor to connect to front/rear led of an EV.
Thank you for contacting NXP Technical support.
Following your inquiry, we have some dynamic block diagrams where you can find some product recommendations to develop your application.
https://www.nxp.com/applications/automotive/body-and-comfort/automotive-advanced-exterior-lighting:A...
On the MPU recommendation, I suggest you check the LX2160A, LS1028A, LS10x3A, or LS20x4A as are the recommended for automotive applications
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/layerscape-processors:QO...
Technical support
