88W9098 Timeout cmd id (27.589481) CHAN_REGION_CFG
johnj_dejero
After loading the driver successfully (tested with both 6.12.34_2.1.0 and lf-6.12.20_2.0.0):
[ 10.246097] wlan: Loading MWLAN driver
[ 10.255576] wlan: Register to Bus Driver...
[ 10.260485] usbcore: registered new interface driver usbxxx
[ 10.260525] wlan_pcie 0000:05:00.0: enabling device (0000 -> 0002)
[ 10.260760] PCI memory map Virt0: 00000000a3674d6f PCI memory map Virt2: 0000000053f18fe1
[ 10.269043] Attach moal handle ops, card interface type: 0x206
[ 10.274941] rps set to f from module param
[ 10.291492] igc 0000:04:00.0 lan0: renamed from eth3
[ 10.298609] PCIE9098: init module param from usr cfg
[ 10.303656] card_type: PCIE9098, config block: 0
[ 10.308328] cfg80211_wext=0xf
[ 10.311851] max_vir_bss=1
[ 10.316042] cal_data_cfg=none
[ 10.319638] drv_mode = 1
[ 10.322765] ps_mode = 2
[ 10.325755] auto_ds = 2
[ 10.328735] host_mlme=enable
[ 10.332161] fw_serial off
[ 10.335728] fw_name=nxp/pcie9098_wlan_v1.bin
[ 10.340656] rx_work=1 cpu_num=4
[ 10.344301] Enable moal_recv_amsdu_packet
[ 10.344442] Attach mlan adapter operations.card_type is 0x206.
[ 10.355619] intel_rapl_msr: PL4 support detected.
[ 10.358439] intel_rapl_common: Found RAPL domain package
[ 10.358444] intel_rapl_common: Found RAPL domain core
[ 10.358445] intel_rapl_common: Found RAPL domain uncore
[ 10.358447] intel_rapl_common: Found RAPL domain psys
[ 10.360956] Request firmware: nxp/pcie9098_wlan_v1.bin
[ 10.634941] FW download over, size 509624 bytes
[ 10.771109] u32 classifier
[ 10.771113] Performance counters on
[ 10.771114] input device check on
[ 10.771115] Actions configured
[ 10.920898] WLAN FW is active
[ 10.924357] on_time is 10923577575
[ 10.943304] VDLL image: len=153752
[ 10.943380] fw_cap_info=0xc8fcefa3, dev_cap_mask=0xffffffff
[ 10.943387] max_p2p_conn = 8, max_sta_conn = 48
[ 10.943389] set int_sel_mask=0x2020001
[ 10.958210] Register NXP 802.11 Adapter mlan0
[ 10.963100] wlan: version = PCIE9098--17.92.1.p149.76-MM6X17540.p7-(FP92)
[ 10.970892] wlan_pcie 0000:05:00.1: enabling device (0000 -> 0002)
[ 10.971118] PCI memory map Virt0: 00000000682d701f PCI memory map Virt2: 00000000da5fa8d7
[ 10.979878] Attach moal handle ops, card interface type: 0x206
[ 10.986225] rps set to f from module param
[ 10.990900] PCIE9098: init module param from usr cfg
[ 10.996392] card_type: PCIE9098, config block: 1
[ 11.001511] cfg80211_wext=0xf
[ 11.004956] max_vir_bss=1
[ 11.008080] cal_data_cfg=none
[ 11.011599] drv_mode = 2
[ 11.014643] ps_mode = 2
[ 11.017536] auto_ds = 2
[ 11.020407] host_mlme=enable
[ 11.023722] fw_serial off
[ 11.026850] fw_name=nxp/pcie9098_wlan_v1.bin
[ 11.031606] rx_work=1 cpu_num=4
[ 11.035223] Enable moal_recv_amsdu_packet
[ 11.035349] Attach mlan adapter operations.card_type is 0x206.
[ 11.036909] Request firmware: nxp/pcie9098_wlan_v1.bin
[ 11.043235] WLAN FW already running! Skip FW download
[ 11.043240] WLAN FW is active
[ 11.046675] on_time is 11045896137
[ 11.051094] VDLL image: len=153752
[ 11.051106] fw_cap_info=0x48fcefa3, dev_cap_mask=0xffffffff
[ 11.051112] max_p2p_conn = 8, max_sta_conn = 48
[ 11.051114] set int_sel_mask=0x2020001
[ 11.051846] wlan: muap%d set max_mtu 2000
[ 11.061600] Register NXP 802.11 Adapter muap0
[ 11.066435] wlan: version = PCIE9098--17.92.1.p149.76-MM6X17540.p7-(FP92)
[ 11.074306] wlan: Register to Bus Driver Done
[ 11.079144] wlan: Driver loaded successfully
Executing `iw reg set` results in:
[ 26.642084] FW trigger fw dump
[ 26.645207] =====FW trigger dump====
[ 26.648952] ==== Start Receive FW dump event ====
[ 26.653824] === START DRIVER INFO DUMP===
[ 26.653886] FW in debug mode (0xea)
[ 26.853243] Drv info total bytes = 248900 (0x3cc44)
[ 26.853247] === DRIVER INFO DUMP END===
[ 26.853248] === START DRIVER INFO DUMP===
[ 26.853394] FW in debug mode (0xea)
[ 27.052742] Drv info total bytes = 248907 (0x3cc4b)
[ 27.052745] === DRIVER INFO DUMP END===
[ 27.819598] Timeout cmd id (27.589481) CHAN_REGION_CFG [0x242], act = 0x1
[ 27.819617] Dump Rx CMD Response Buf:
[ 27.819621] CmdResp Buf:
[ 27.819629] 63 00 01 00 5b 00 5f 00 19 10 00 00 01 00 07 00
[ 27.819635] 45 00 43 41 20 24 01 17 28 01 17 2c 01 17 30 01
[ 27.819641] 17 34 01 17 38 01 17 3c 01 17 40 01 17 64 01 17
[ 27.819646] 68 01 17 6c 01 17 70 01 17 74 01 17 84 01 17 88
[ 27.819649] BSS type = 1 BSS role= 1
[ 27.819653] ------------Dump info-----------
[ 27.820163] -------- Dump info End---------
[ 27.820175] Host:igw-605000031 Timestamp:2025-10-23 13:31:20
[ 27.820182] Driver version = PCIE9098--17.92.1.p149.76-MM6X17540.p7-(FP92)
[ 27.820185] main_state = 4
[ 27.820187] ioctl_pending = 1
[ 27.820190] tx_pending = 0
[ 27.820192] wmm_tx_pending[0] = 0
[ 27.820194] wmm_tx_pending[1] = 0
[ 27.820197] wmm_tx_pending[2] = 0
[ 27.820199] wmm_tx_pending[3] = 0
[ 27.820201] rx_pending = 0
[ 27.820203] lock_count = 44
[ 27.820206] malloc_count = 48
[ 27.820208] mbufalloc_count = 136
[ 27.820211] malloc_cons_count = 4
[ 27.820213] hs_skip_count = 0
[ 27.820216] hs_force_count = 0
[ 27.820218] Media state = "Disconnected"
[ 27.820221] carrier off
[ 27.820224] tx queue 0: stopped
[ 27.820227] tx queue 1: stopped
[ 27.820230] tx queue 2: stopped
[ 27.820233] tx queue 3: stopped
[ 27.820235] hotspot0: num_tx_timeout = 0
[ 27.820244] Config Space Registers:
[ 27.823829] reg:0x00 value=0x2b441b4b
[ 27.823835] reg:0x04 value=0x00100406
[ 27.823840] reg:0x10 value=0x0000000c
[ 27.823844] reg:0x18 value=0x81000004
[ 27.823848] reg:0x2c value=0x2b441b4b
[ 27.823852] reg:0x3c value=0x000002ff
[ 27.823856] reg:0x44 value=0x00000008
[ 27.823860] reg:0x80 value=0x10120140
[ 27.823864] reg:0x98 value=0x00000000
[ 27.823869] reg:0x170 value=0x0001001e
[ 27.823874] FW in debug mode (0xea)
[ 27.823876] FW Scrach Registers:
[ 27.827147] reg:0x1c90 value=0xfedcba00
[ 27.827151] reg:0x1c98 value=0x126ea69
[ 27.827155] reg:0x1c9c value=0x1000030
[ 27.926368] reg:0x1c98 value=0x126ea69
[ 27.926373] reg:0x1c9c value=0x1000030
[ 28.023800] ==== FW DUMP END: 2360256 bytes ====
Other info:
OS: Debian GNU/Linux 12 (bookworm)
Kernel version: 6.12.22-igw-amd64
CPU: Intel(R) Atom(TM) x7433RE
Wifi card: NXP 88W9098 Wi-Fi 6 (ax) MAC (rev 03)
shaun_wu
Hello @johnj_dejero
Could you share full cmd you issued of "iw reg set"? Which region code you are using?
Best Regards
Shaun
johnj_dejero
iw reg set CA
But it's happening for any region (US, JP, CN etc.)
shaun_wu
Hello @johnj_dejero
We provide methods to configure tx power limit, you could refer to following method to update power limite table. Due to I'm not familiar with the host you used, maybe they didn't provide country code power table in their system.
https://www.nxp.com/webapp/Download?colCode=AN13463&appType=license
Best Regards
Shaun
johnj_dejero
The download above fails with:
Your userId does not have sufficient privilege to proceed with download.
Our OS is debian with kernel version 6.12 and the regulatory databse is present at /lib/firmware/regulatory.db
Note that we were able to configure the country code via /etc/modprobe.d/cfg80211.conf
options cfg80211 ieee80211_regdom=CA
But we are unable to change it with iw reg set, because of the firmware issue above.
johnj_dejero
Also related `iw dev` shows 0 dBm txpower for the interface:
Interface hotspot0
ifindex 22
wdev 0x700000001
addr 60:09:c3:84:f1:76
ssid 605000031
type AP
channel 44 (5220 MHz), width: 40 MHz, center1: 5230 MHz
txpower 0.00 dBm
Even though the region in the kernel ends up being configured to CA, it seems like the firmware doesn't get properly configured.
iw reg get
global
country CA: DFS-ETSI
(2402 - 2482 @ 40), (N/A, 20), (N/A)
(5170 - 5250 @ 80), (N/A, 23), (W)
(5250 - 5330 @ 80), (N/A, 20), (W), DFS
shaun_wu
Hello @johnj_dejero
I tried your problem on our platform, there are no problem. I think you may need to check host side setup.
Best Regards
Shaun
%3CLINGO-SUB%20id%3D%22lingo-sub-2191610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E88W9098%20Timeout%20cmd%20id%20(27.589481)%20CHAN_REGION_CFG%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAfter%20loading%20the%20driver%20successfully%20(tested%20with%20both%206.12.34_2.1.0%20and%20lf-6.12.20_2.0.0)%3A%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.246097%5D%20wlan%3A%20Loading%20MWLAN%20driver%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.255576%5D%20wlan%3A%20Register%20to%20Bus%20Driver...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.260485%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbxxx%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.260525%5D%20wlan_pcie%200000%3A05%3A00.0%3A%20enabling%20device%20(0000%20-%26gt%3B%200002)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.260760%5D%20PCI%20memory%20map%20Virt0%3A%2000000000a3674d6f%20PCI%20memory%20map%20Virt2%3A%200000000053f18fe1%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.269043%5D%20Attach%20moal%20handle%20ops%2C%20card%20interface%20type%3A%200x206%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.274941%5D%20rps%20set%20to%20f%20from%20module%20param%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.291492%5D%20igc%200000%3A04%3A00.0%20lan0%3A%20renamed%20from%20eth3%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.298609%5D%20PCIE9098%3A%20init%20module%20param%20from%20usr%20cfg%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.303656%5D%20card_type%3A%20PCIE9098%2C%20config%20block%3A%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.308328%5D%20cfg80211_wext%3D0xf%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.311851%5D%20max_vir_bss%3D1%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.316042%5D%20cal_data_cfg%3Dnone%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.319638%5D%20drv_mode%20%3D%201%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.322765%5D%20ps_mode%20%3D%202%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.325755%5D%20auto_ds%20%3D%202%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.328735%5D%20host_mlme%3Denable%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.332161%5D%20fw_serial%20off%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.335728%5D%20fw_name%3Dnxp%2Fpcie9098_wlan_v1.bin%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.340656%5D%20rx_work%3D1%20cpu_num%3D4%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.344301%5D%20Enable%20moal_recv_amsdu_packet%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.344442%5D%20Attach%20mlan%20adapter%20operations.card_type%20is%200x206.%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.355619%5D%20intel_rapl_msr%3A%20PL4%20support%20detected.%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.358439%5D%20intel_rapl_common%3A%20Found%20RAPL%20domain%20package%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.358444%5D%20intel_rapl_common%3A%20Found%20RAPL%20domain%20core%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.358445%5D%20intel_rapl_common%3A%20Found%20RAPL%20domain%20uncore%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.358447%5D%20intel_rapl_common%3A%20Found%20RAPL%20domain%20psys%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.360956%5D%20Request%20firmware%3A%20nxp%2Fpcie9098_wlan_v1.bin%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.634941%5D%20FW%20download%20over%2C%20size%20509624%20bytes%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.771109%5D%20u32%20classifier%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.771113%5D%20Performance%20counters%20on%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.771114%5D%20input%20device%20check%20on%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.771115%5D%20Actions%20configured%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.920898%5D%20WLAN%20FW%20is%20active%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.924357%5D%20on_time%20is%2010923577575%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.943304%5D%20VDLL%20image%3A%20len%3D153752%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.943380%5D%20fw_cap_info%3D0xc8fcefa3%2C%20dev_cap_mask%3D0xffffffff%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.943387%5D%20max_p2p_conn%20%3D%208%2C%20max_sta_conn%20%3D%2048%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.943389%5D%20set%20int_sel_mask%3D0x2020001%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.958210%5D%20Register%20NXP%20802.11%20Adapter%20mlan0%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.963100%5D%20wlan%3A%20version%20%3D%20PCIE9098--17.92.1.p149.76-MM6X17540.p7-(FP92)%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.970892%5D%20wlan_pcie%200000%3A05%3A00.1%3A%20enabling%20device%20(0000%20-%26gt%3B%200002)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.971118%5D%20PCI%20memory%20map%20Virt0%3A%2000000000682d701f%20PCI%20memory%20map%20Virt2%3A%2000000000da5fa8d7%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.979878%5D%20Attach%20moal%20handle%20ops%2C%20card%20interface%20type%3A%200x206%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.986225%5D%20rps%20set%20to%20f%20from%20module%20param%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.990900%5D%20PCIE9098%3A%20init%20module%20param%20from%20usr%20cfg%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2010.996392%5D%20card_type%3A%20PCIE9098%2C%20config%20block%3A%201%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.001511%5D%20cfg80211_wext%3D0xf%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.004956%5D%20max_vir_bss%3D1%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.008080%5D%20cal_data_cfg%3Dnone%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.011599%5D%20drv_mode%20%3D%202%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.014643%5D%20ps_mode%20%3D%202%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.017536%5D%20auto_ds%20%3D%202%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.020407%5D%20host_mlme%3Denable%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.023722%5D%20fw_serial%20off%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.026850%5D%20fw_name%3Dnxp%2Fpcie9098_wlan_v1.bin%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.031606%5D%20rx_work%3D1%20cpu_num%3D4%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.035223%5D%20Enable%20moal_recv_amsdu_packet%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.035349%5D%20Attach%20mlan%20adapter%20operations.card_type%20is%200x206.%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.036909%5D%20Request%20firmware%3A%20nxp%2Fpcie9098_wlan_v1.bin%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.043235%5D%20WLAN%20FW%20already%20running!%20Skip%20FW%20download%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.043240%5D%20WLAN%20FW%20is%20active%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.046675%5D%20on_time%20is%2011045896137%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.051094%5D%20VDLL%20image%3A%20len%3D153752%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.051106%5D%20fw_cap_info%3D0x48fcefa3%2C%20dev_cap_mask%3D0xffffffff%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.051112%5D%20max_p2p_conn%20%3D%208%2C%20max_sta_conn%20%3D%2048%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.051114%5D%20set%20int_sel_mask%3D0x2020001%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.051846%5D%20wlan%3A%20muap%25d%20set%20max_mtu%202000%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.061600%5D%20Register%20NXP%20802.11%20Adapter%20muap0%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.066435%5D%20wlan%3A%20version%20%3D%20PCIE9098--17.92.1.p149.76-MM6X17540.p7-(FP92)%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.074306%5D%20wlan%3A%20Register%20to%20Bus%20Driver%20Done%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2011.079144%5D%20wlan%3A%20Driver%20loaded%20successfully%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EExecuting%20%60iw%20reg%20set%60%20results%20in%3A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2026.642084%5D%20FW%20trigger%20fw%20dump%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2026.645207%5D%20%3D%3D%3D%3D%3DFW%20trigger%20dump%3D%3D%3D%3D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2026.648952%5D%20%3D%3D%3D%3D%20Start%20Receive%20FW%20dump%20event%20%3D%3D%3D%3D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2026.653824%5D%20%3D%3D%3D%20START%20DRIVER%20INFO%20DUMP%3D%3D%3D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2026.653886%5D%20FW%20in%20debug%20mode%20(0xea)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2026.853243%5D%20Drv%20info%20total%20bytes%20%3D%20248900%20(0x3cc44)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2026.853247%5D%20%3D%3D%3D%20DRIVER%20INFO%20DUMP%20END%3D%3D%3D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2026.853248%5D%20%3D%3D%3D%20START%20DRIVER%20INFO%20DUMP%3D%3D%3D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2026.853394%5D%20FW%20in%20debug%20mode%20(0xea)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.052742%5D%20Drv%20info%20total%20bytes%20%3D%20248907%20(0x3cc4b)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.052745%5D%20%3D%3D%3D%20DRIVER%20INFO%20DUMP%20END%3D%3D%3D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.819598%5D%20Timeout%20cmd%20id%20(27.589481)%20CHAN_REGION_CFG%20%5B0x242%5D%2C%20act%20%3D%200x1%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.819617%5D%20Dump%20Rx%20CMD%20Response%20Buf%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.819621%5D%20CmdResp%20Buf%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.819629%5D%2063%2000%2001%2000%205b%2000%205f%2000%2019%2010%2000%2000%2001%2000%2007%2000%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.819635%5D%2045%2000%2043%2041%2020%2024%2001%2017%2028%2001%2017%202c%2001%2017%2030%2001%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.819641%5D%2017%2034%2001%2017%2038%2001%2017%203c%2001%2017%2040%2001%2017%2064%2001%2017%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.819646%5D%2068%2001%2017%206c%2001%2017%2070%2001%2017%2074%2001%2017%2084%2001%2017%2088%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.819649%5D%20BSS%20type%20%3D%201%20BSS%20role%3D%201%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.819653%5D%20------------Dump%20info-----------%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E...%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820163%5D%20--------%20Dump%20info%20End---------%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820175%5D%20Host%3Aigw-605000031%20Timestamp%3A2025-10-23%2013%3A31%3A20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820182%5D%20Driver%20version%20%3D%20PCIE9098--17.92.1.p149.76-MM6X17540.p7-(FP92)%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820185%5D%20main_state%20%3D%204%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820187%5D%20ioctl_pending%20%3D%201%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820190%5D%20tx_pending%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820192%5D%20wmm_tx_pending%5B0%5D%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820194%5D%20wmm_tx_pending%5B1%5D%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820197%5D%20wmm_tx_pending%5B2%5D%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820199%5D%20wmm_tx_pending%5B3%5D%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820201%5D%20rx_pending%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820203%5D%20lock_count%20%3D%2044%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820206%5D%20malloc_count%20%3D%2048%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820208%5D%20mbufalloc_count%20%3D%20136%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820211%5D%20malloc_cons_count%20%3D%204%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820213%5D%20hs_skip_count%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820216%5D%20hs_force_count%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820218%5D%20Media%20state%20%3D%20%22Disconnected%22%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820221%5D%20carrier%20off%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820224%5D%20tx%20queue%200%3A%20stopped%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820227%5D%20tx%20queue%201%3A%20stopped%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820230%5D%20tx%20queue%202%3A%20stopped%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820233%5D%20tx%20queue%203%3A%20stopped%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820235%5D%20hotspot0%3A%20num_tx_timeout%20%3D%200%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.820244%5D%20Config%20Space%20Registers%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823829%5D%20reg%3A0x00%20value%3D0x2b441b4b%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823835%5D%20reg%3A0x04%20value%3D0x00100406%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823840%5D%20reg%3A0x10%20value%3D0x0000000c%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823844%5D%20reg%3A0x18%20value%3D0x81000004%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823848%5D%20reg%3A0x2c%20value%3D0x2b441b4b%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823852%5D%20reg%3A0x3c%20value%3D0x000002ff%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823856%5D%20reg%3A0x44%20value%3D0x00000008%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823860%5D%20reg%3A0x80%20value%3D0x10120140%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823864%5D%20reg%3A0x98%20value%3D0x00000000%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823869%5D%20reg%3A0x170%20value%3D0x0001001e%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823874%5D%20FW%20in%20debug%20mode%20(0xea)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.823876%5D%20FW%20Scrach%20Registers%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.827147%5D%20reg%3A0x1c90%20value%3D0xfedcba00%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.827151%5D%20reg%3A0x1c98%20value%3D0x126ea69%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.827155%5D%20reg%3A0x1c9c%20value%3D0x1000030%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.926368%5D%20reg%3A0x1c98%20value%3D0x126ea69%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2027.926373%5D%20reg%3A0x1c9c%20value%3D0x1000030%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%2028.023800%5D%20%3D%3D%3D%3D%20FW%20DUMP%20END%3A%202360256%20bytes%20%3D%3D%3D%3D%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EOther%20info%3A%3C%2FP%3E%3CP%3EOS%3A%20Debian%20GNU%2FLinux%2012%20(bookworm)%3C%2FP%3E%3CP%3EKernel%20version%3A%206.12.22-igw-amd64%3C%2FP%3E%3CP%3ECPU%3A%26nbsp%3BIntel(R)%20Atom(TM)%20x7433RE%3C%2FP%3E%3CP%3EWifi%20card%3A%26nbsp%3BNXP%2088W9098%20Wi-Fi%206%20(ax)%20MAC%20(rev%2003)%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2088W9098%20Timeout%20cmd%20id%20(27.589481)%20CHAN_REGION_CFG%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256063%22%20target%3D%22_blank%22%3E%40johnj_dejero%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20tried%20your%20problem%20on%20our%20platform%2C%20there%20are%20no%20problem.%20I%20think%20you%20may%20need%20to%20check%20host%20side%20setup.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22shaun_wu_0-1762324472221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shaun_wu_0-1762324472221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364041i901C5B0070C1176B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22shaun_wu_0-1762324472221.png%22%20alt%3D%22shaun_wu_0-1762324472221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3EShaun%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2088W9098%20Timeout%20cmd%20id%20(27.589481)%20CHAN_REGION_CFG%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAlso%20related%20%60iw%20dev%60%20shows%200%20dBm%20txpower%20for%20the%20interface%3A%3CBR%20%2F%3EInterface%20hotspot0%3CBR%20%2F%3Eifindex%2022%3CBR%20%2F%3Ewdev%200x700000001%3CBR%20%2F%3Eaddr%2060%3A09%3Ac3%3A84%3Af1%3A76%3CBR%20%2F%3Essid%20605000031%3CBR%20%2F%3Etype%20AP%3CBR%20%2F%3Echannel%2044%20(5220%20MHz)%2C%20width%3A%2040%20MHz%2C%20center1%3A%205230%20MHz%3CBR%20%2F%3Etxpower%200.00%20dBm%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EEven%20though%20the%20region%20in%20the%20kernel%20ends%20up%20being%20configured%20to%20CA%2C%20it%20seems%20like%20the%20firmware%20doesn't%20get%20properly%20configured.%3C%2FP%3E%3CP%3Eiw%20reg%20get%3C%2FP%3E%3CP%3Eglobal%3CBR%20%2F%3Ecountry%20CA%3A%20DFS-ETSI%3CBR%20%2F%3E(2402%20-%202482%20%40%2040)%2C%20(N%2FA%2C%2020)%2C%20(N%2FA)%3CBR%20%2F%3E(5170%20-%205250%20%40%2080)%2C%20(N%2FA%2C%2023)%2C%20(W)%3CBR%20%2F%3E(5250%20-%205330%20%40%2080)%2C%20(N%2FA%2C%2020)%2C%20(W)%2C%20DFS%3CBR%20%2F%3E...%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2088W9098%20Timeout%20cmd%20id%20(27.589481)%20CHAN_REGION_CFG%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThe%20download%20above%20fails%20with%3A%3CBR%20%2F%3EYour%20userId%20does%20not%20have%20sufficient%20privilege%20to%20proceed%20with%20download.%3CBR%20%2F%3E%3CBR%20%2F%3EOur%20OS%20is%20debian%20with%20kernel%20version%206.12%20and%20the%20regulatory%20databse%20is%20present%20at%20%2Flib%2Ffirmware%2Fregulatory.db%3CBR%20%2F%3E%3CBR%20%2F%3ENote%20that%20we%20were%20able%20to%20configure%20the%20country%20code%20via%20%2Fetc%2Fmodprobe.d%2Fcfg80211.conf%3CBR%20%2F%3Eoptions%20cfg80211%20ieee80211_regdom%3DCA%3CBR%20%2F%3E%3CBR%20%2F%3EBut%20we%20are%20unable%20to%20change%20it%20with%20iw%20reg%20set%2C%20because%20of%20the%20firmware%20issue%20above.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2088W9098%20Timeout%20cmd%20id%20(27.589481)%20CHAN_REGION_CFG%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256063%22%20target%3D%22_blank%22%3E%40johnj_dejero%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EWe%20provide%20methods%20to%20configure%20tx%20power%20limit%2C%20you%20could%20refer%20to%20following%20method%20to%20update%20power%20limite%20table.%20Due%20to%20I'm%20not%20familiar%20with%20the%20host%20you%20used%2C%20maybe%20they%20didn't%20provide%20country%20code%20power%20table%20in%20their%20system.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN13463%26amp%3BappType%3Dlicense%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN13463%26amp%3BappType%3Dlicense%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3EShaun%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2088W9098%20Timeout%20cmd%20id%20(27.589481)%20CHAN_REGION_CFG%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eiw%20reg%20set%20CA%3CBR%20%2F%3E%3CBR%20%2F%3EBut%20it's%20happening%20for%20any%20region%20(US%2C%20JP%2C%20CN%20etc.)%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%2088W9098%20Timeout%20cmd%20id%20(27.589481)%20CHAN_REGION_CFG%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256063%22%20target%3D%22_blank%22%3E%40johnj_dejero%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ECould%20you%20share%20full%20cmd%20you%20issued%20of%20%22%3CSPAN%3Eiw%20reg%20set%22%3F%20Which%20region%20code%20you%20are%20using%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBest%20Regards%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EShaun%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
