Hi, exist the layout for the 380--450 MHz UHF Broadband, 136--174 MHz VHF Broadband, or the 450--520 MHz UHF broadband?
Into the product page only is provided a dxf file for the 520 MHz Narrowband application.
Below is the layout file that I am looking for:
Best Regards
Franco
Solved! Go to Solution.
Dear Andrei,
Great! Thank you. How about the other networks for the 136--174 MHz VHF Broadband and the 450--520 MHz UHF broadband?
The board have small changes but if you could provide the dxf board that would be great.
Best Regards
Franco
Provided by direct email.
can you share dxf files for 136--174 MHz VHF Broadband and the 380--450 MHz UHF broadband with me too? if possible plzz share gerber as well.
