UWB SR150: Will the CIR raw data be available?
georgf
Hi, is there a roadmap or are the any plans to make the raw CIR data available with the SR150 UWB module?
Tags (2)
Ricardo_Zamora
Hope you are doing well. Are you using one these Development Kits or Modules (UWB Developer Resources)?
If that is the case you would need to redirect your questions to the Module Maker, also it is good to go with them to know the process and the support that they can provide you.
I apologize for the inconveniences this might cause you.
Ricardo
Ricardo_Zamora
Ricardo
