Raw Signals (I/Q) For RoadLINK® SAF5400
abhayrjoshi
Could you confirm if it is possible to access the raw signal data from the RoadLINK® SAF5400 modem? We are considering using the development kit for our prototyping needs and would appreciate any information on this functionality.
Ricardo_Zamora
Hope you are doing well. I'm sorry for the inconveniences this may cause, but, unfortunately, information about the SAF5400 and other V2X Automotive Products is protected under a Non-Disclosure Agreement.
To obtain information about these products, could you please contact your Local Distributor from the Distributor Network so they can not only help you with the NDA process but also provide you the information you might need of those products?
Ricardo
