having difficulties comunicating via BDM
1,260 次查看
arshagminelian
Hi There
we're having difficulties comunicating via BDM with:
KIT912S812ECUEVM Small Engine Reference Design Featuring the MM912_S812 MCU and Ignition/Injector Driver System-in-Package
标记 (1)
954 次查看
iggi
Do you use OSBDM on board or external programmer (which one)?
What CodeWarrior version do you use?
What Windows version do you use (XP, 7, 32-bit, 64-bit )?
Can you describe the difficulties you are having more in details?
