can USBDM be used in Keil?
wangbaode
Hi pgo,
I want to use Kinetis chip,can I use USBDM in Keil?
Tags (2)
pgo
Senior Contributor V
Hi Wang,
Keil is not supported by USBDM.  AFAIK the specifications for the Keil interface is not publicly available.
bye
wangbaode
Hi pgo,
Thank you for your answer.
wangbaode
it's not PE micro.it's just USBDM,a open source BDM.
