WTBDM problem
WTBDM problem
969件の閲覧回数
elettronicarewo
Hi! I've an old WTBDMS08, JB16(28-PIN based); I need to flash an hcs12, so i've tried to update fw. I installed USBDM 4.11.1.20, and run firmware update. but the application dosen't recognized my tool and said (USB unknown error). so i flashed  JB16 with the WTBDM_JB16.s19 (found in FlashImages folder); Windows don't recognized the Hw, it said "Unkown device", and when i tried to install driver it don't acept it. Anyone can help me to solve my problem? (I use Win7 32-bit, codewarrior 6.3)
5 返答(返信)
690件の閲覧回数
pgo
Senior Contributor V
I'm sorry but due to problems with the JB16 chip in later versions of Windows (WIN-XP SP3 onwards) it is no longer supported by USBDM.
In particular it is is not possible to use the ICP function (at least not an any machine I've tried).
I will have a look at the firmware you mentioned and see if I can see an workable solution.
bye
PS - How did you update the firmware?
690件の閲覧回数
elettronicarewo
I've flashed JB16 with softech indart for hc08; for now i've found the old fw so my device work again but only with hcs08; there is a way to make it work with hcs12?
690件の閲覧回数
pgo
I tried the latest version of USBDM (V4.11.1.4) with a Witztronics JB16 BDM and it seems to work OK with a HCS12 device.
I used the firmware included (V4.10.2) with that release.
I had to do the firmware update on a Linux machine.
bye
690件の閲覧回数
elettronicarewo
i'm late, sorry; i'll try soon under linux. tanks for help. i'l try and report.
690件の閲覧回数
Witztronics
Since that is an older, unsupported product, we'd be glad to offer you a discount on a new WTBDMJS16.
contact us at our website:
http://www.witztronics.com
Witztronics
www.witztronics.com
