Hi Johnny,
I only tested with a MKE02Z16M2. The SDID is not correct for the other two chips in the family I probably cut'n'pasted them and forgot to change them.
You can edit the device description file (path may vary):
C:\Program Files (x86)\pgo\USBDM 4.10.6.120\DeviceData\arm_devices.xml
and locate the entry for the device you are using and change the SDID line as shown below.
<sdid value="0x02040000" /> |
Please confirm if this works.
bye
