USBDM can't debug watchdog in MC9S08PA16
1,102件の閲覧回数
wangbaode
Hi pgo,
I find a bug of USBDM.I new a project of Mc9S08PA16.I download the program into pA16 and watch WDOG register.
the value is different from the default value of PA16.when i download program into PA16 through multilink.the value is same as the default value in datasheet.
so I think it's a bug.can you try it?
bye
タグ(2)
3 返答(返信)
905件の閲覧回数
pgo
Senior Contributor V
Hi Wang,
This issue has been corrected in the current version just uploaded to Sourceforge.
bye
905件の閲覧回数
wangbaode
Dear pgo,
905件の閲覧回数
pgo
Hi Wang,
You are quite correct.  Unfortunately I can't see any way around this.
USBDM modifies the target registers to allow programming.  After programming the device is reset.  Unfortunately the Watchdog is not reset by a software reset - It appears to only be reset by a power-on-reset.
If you cycle power to to the target during your debugging session (and clear the USBDM connection dialogue that pops-up) you can restore the power-on-values.
Software reset in the debugger will not achieve this - The watchdog is unchanged.
I'm unsure how the Multi-link works.
bye
PS. I will modify the flash programming code so it doesn't lock the WDOG (if possible).
