USBDM MKE16Z64VLF4 XML file
m_giraldi
ARM Programmer Does Not Detect MKE16Z64
I made a big project (5000 pieces month) and asked to buy a usbdm to record the MKE16Z64VLF4, but I had the surprise that this micro is not in the list. What to do? Would it be possible to generate a version of USBDM (XML) that contains MKE16Z64? When I ask to detect the chip, it suggests the MK10FN1M0M12 with CHIP ID 16240186. I am using the ARM Programmer.
I have another project that uses the MK22FN512M12 and works perfectly with USBDM.
