USBDM: Can´t "load and go" with MC9S08PA4,MC9S08PA8,MC9S08PA16,..
Search instead for
Hi PGO,
About HCS08 Programmer with USBDM_JMxxCLD: I´d like to understand why "load and go" does not work for MC9S08PA8. It load and can´t go (do not execute).
Where is the  XML that contain the address to start running? I see the "_entry_point" reset vector is 0xFFFE. It is the same of the others like QE8. Why QE8 works and PA8 does not work?
How to fix it?
Senior Contributor V
Hi Luciano,
I have located the problem and I expect it to fixed in the next version.
bye
