Q>connecting the J3 of tbml to programm a uC?
6,060 次查看
daistar
how will i connect the J3 fo tbml in order to program a uC?? like what are the pins description of the J3 and where to connect it in to a uC??? a schematic will be very helpful... tnx
4 回复数
1,892 次查看
daistar
what is EVB and tnx for replying.....
1,892 次查看
daistar
oh shoot...i'm sorry i've got confused of the word BDM.........just to clarify pin1 should be connected to BKGD/TAGHI/MODC...right? and pin4 to RESET..right? of 9s12dp512
1,893 次查看
DanielM
get yourself a schematic of an EVB. Essentially you are right, but you will also need pull-ups on both lines.
1,893 次查看
Alban
Senior Contributor II
If you read the TBDML_manual_15.pdf included in the archive...
Funnily enough, that is the User Guide and the Schematics !!!
Alban.
