Q>connecting the J3 of tbml to programm a uC?
5,987件の閲覧回数
daistar
how will i connect the J3 fo tbml in order to program a uC?? like what are the pins description of the J3 and where to connect it in to a uC??? a schematic will be very helpful... tnx
4 返答(返信)
1,819件の閲覧回数
daistar
what is EVB and tnx for replying.....
1,819件の閲覧回数
daistar
oh shoot...i'm sorry i've got confused of the word BDM.........just to clarify pin1 should be connected to BKGD/TAGHI/MODC...right? and pin4 to RESET..right? of 9s12dp512
1,820件の閲覧回数
DanielM
get yourself a schematic of an EVB. Essentially you are right, but you will also need pull-ups on both lines.
1,820件の閲覧回数
Alban
Senior Contributor II
If you read the TBDML_manual_15.pdf included in the archive...
Funnily enough, that is the User Guide and the Schematics !!!
Alban.
