NO ICP for MC908JB16
8,783 次查看
compuboy
Hello All Gurus !
I have built the OSBDM Board and now i am trying to program it using the USBICP
When i place the JP3 and JP4 in ICP Mode the PC does not even detect an unknown device.
When i place the JP3 and JP4 in normal mode the PC recognizes an Unknown Device but i am not able to install the drivers for USBICP.
What should i do?
Am i missing anything?
- Shantur
标记 (2)
3 回复数
1,390 次查看
JCC
You must solder a .1uf capacitor between RESET and GROUND in order to be recognised by Windows.
JC
P.S. I realize that I'm a bit late, so I sent a personal e-mail.
1,390 次查看
peg
Senior Contributor IV
Hi Shantur,
Take a look at this old thread:
It may shed some light on the reason for your issue.
1,390 次查看
Witztronics
Shantur,
I have attached Freescale application note AN2399.
This Ap note explains how to ICP program a blank 908JB16.
The OSBDM firmware also allows for re-programming the 908JB16.  You would need to refer to the documentation for the version you have built, but it's basically pulling down PTA0 before pluggin in the OSBDM puts it into ICP mode if you used the ICP version of the firmware.
I hope this helps.
Message Edited by Witztronics on 2007-09-07 03:11 PM
AN23991.pdf
Message Edited by t.dowe on 2009-09-14 06:12 PM
