The process to check the installation of USBDM in Codewarrior 10.x
Assumes the following:
Procedure:
This should produce a dialogue similar to:
This should open a dialogue with details about the USBDM plugin.
Confirm that the version agrees with what you expect.
If the above appears then the USBDM plugins has been installed.
The above dialogue shows the expected plugins that make up USBDM.
If the above is not found then it is suggested that you uninstall and re-install USBDM. It may be necessary to do this if you upgrade the components of Codewarrior.
When re-installing make sure that the Codewarrior installation is correctly detected.
bye
How can we use USBDM in CodeWarrior 10.7?
Fixed in lastest release.
