Does OSBDM-JM60 support MCF51AC128A?
bluehacker
Hi, everyone!
I found one issue about OSBDM-JM60. when I debug MCF51AC128A board using OSBDM-JM60, if click "change MCU/Connection..." button, in the "device and connection" dialog, I can't find "CFV1 FSL Open SOurce BDM" item.
But if I select MCF51cn128 ,the item appears.
How does I debug mcf51ac128a using OSBDM-JM60?
Tags (2)
Hokke
(In debugger)
Component - Set Connection
'Connection'
'CFV1 Open Source BDM'
'FSL Open Source BDM'
Thank you
Zahar
Hello Bluehacker,
Which version of Codewarrior are you using?
Zahar
P&E
