I know it has less flash, but maybe it fits. I am planning to use it to program a MCF52 Coldfire v2. Thanks!
Dear Leonel,
My short answer is: Yes, you can!
Good luck!
Celso
Hi Leonel,
I suggest you look at the table on this page:
This has a table showing all version.
Which you choose depends on whether you can program a JM60 or need to use a JS16 which doesn't require a programmer.
After that it depends upon which you feel up to building.
bye
Hi Leonel,
The flash image is located so as to be compatible with a MC9S08JM32.
It's always desirable to use the larger device in case of the image growing.
bye
What USBDM do you recommend to me?
Bye!
