BDM go problem on mc9s08jm32
1,692 次查看
jprogram
I've been messing around with writing to flash on a mc9s08jm32 using a bdm programmer I made.
It seemed like it was writing to flash, I'm still not sure. The problem though is that I load a program into ram and set PC to the location in ram but then I send the 'go' command (0x08) and it doesn't run. I used to be able to run programs this way but after trying to write flash, 'go' just seemed to stop working.
any ideas?
标记 (2)
0 回复数
