sending/receiving udp messages and bind error
flaminatakam
I am trying to send UDP messages between two frdm-KW41Z.
Once, i succeeded to open a socket and send data but the message didn't appear in the receiver shell.
I closed the socket and try again
I am getting this error. How can i fix it? is there a way to change the port number in the code files?
mariuslucianand
Hello flaminatakam@gmail.com‌,
This community space do not cover the topic you need assistance on.
Please create new thread on the Kinetis Microcontrollers community space or new NXP support case according to following procedure:https://community.nxp.com/docs/DOC-329745
Hope this helps,
Marius
flaminatakam
Okay, Thanks
