how to build program generated by mbd Toolbox in the keil?
642142357
how to setup a project or  build  program  generated by  mbd Toolbox in the keil5?  constantinrazvan.chivu
constantinrazva
Hello 642142357@qq.com,
Unfortunately we do not have support for exporting projects generated from our toolbox to Keil5 uVision 5 IDE - if you want to bring it there, you'll have to manually set it up (copy the files would be easy, but you'll also have to set the linker files to be used, etc.). The only IDE that we export to is S32Design Studio - for that you'll do a simple import and you'll have everything set-up.
Kind regards,
Razvan.
mariuslucianand
Hello 642142357@qq.com‌,
The only suggestion I have, in addition to what constantinrazvan.chivu recommended to you, is once you have imported the code in S32DS, to export it to be used for Keil. Maybe this link can help you Using Keil μVision 5 with Processor Expert | MCU on Eclipse
Hope this helps,
Marius
