It is impossible to recognize messages which sent via UART (uart_hello_world_mpc574xP model) from MPC5775B BMS Plus VCU Reference Design board.
There is no any problem when same model is used together with DEVKIT MPC5744P.
Solved! Go to Solution.
Hello @sonik82 ,
We have a model in the toolbox for the MPC5777C which is basically the same as the MPC5775B that you are trying on. I see no problems with this one. Can you please give it a try? Also, I've uploaded the model here.
Hope this helps,
Marius
Hello @sonik82 ,
Hope this helps,
Marius
@mariuslucianand Thank you, uart_hello_world_mpc5777C works fine.
@mariuslucianand Thank you for information about MPC5777C UART hello world example model. I didn't know about this model because it is not in my library.
But I found it in explorer
So today I am going to try this model and let you know results.
I'm having the same problem with the MPC5775B Evaluation board,
it works if I choose the MPC5775C processor, seems the clock is different, but not clear what else is changed.
