S32K144 cannot be flashed
aungkm
I could not flash a new firmware to the s32k144evb-q100 after flashing it with the Simulink example model called csec_keyconfig_s32k14x which came with the MBDT. The reset button does not seem to be resetting the MCU.
I have also attached the model with this thread.
Any idea on how to fix it?
Your help is really appreciated.
Thank you!
Aung
constantinrazva
Hello aungkm@outlook.com ,
I think paulvlase‌ can help you on this subject [thanks in advance Paul!].
Kind regards,
Razvan.
