Motor Control Class: Lecture 2 - Application Partitioning
dumitru-daniel_
In this second lecture of the motor control course we discuss about software and hardware main components that we are going to implement and use. Starting from a comparison between DC vs. BLDC motor construction we discuss step-by-step all the key elements needed for a closed loop speed control system.
Main topics:
    - DC vs BLDC motors;
    - BLDC motor - how is made;
    - BLDC motor - how it works;
    - Position sensors - how it works;
    - Block diagram for a speed control system;
    - Mapping application over the MPC5744P and MotorGD hardware components;
    - Final setup we will use for implementing the control algorithms;
Objectives:
    - Understand how the BLDC commutation works;
    - Understand the key elements needed for a closed loop speed control;
    - Map an algorithm over the MPC5744P microprocessor;
    - Become familiar with the final HW setup;
Watch the video and leave your comments and questions below.
Additional information:
    - pdf attached with slides shown in this video;
NOTE: Chinese viewers can watch the video on YOUKU using this link.
注意:中国观众可以使用此链接观看YOUKU上的视频
