Memory copy implementation
Search instead for
raghurajappa
I was looking at the following block available from Mathworks for Arduino.
https://nl.mathworks.com/help/ecoder/ref/memorycopy.html
But I couldn't see the source code (s-function/tlc) and it's implementation. Is there some example code available to start with, for implementing a memory copy block in Simulink.
We're using MPC5745R microcontroller and the block is also intended for this microcontroller.
dumitru-daniel_
Hi Raghu,
Sorry for the long delay - apparently this has been overlooked. We do have our own implementation via DMA in case you wish to have a look over.
