For the board MPC57xx it supports 8 can channels. I'm using Model-Based Design Toolbox for MPC57xx Series Version 3.2.0.
In the drop down list of CAN bus channel in CAN Transmit and receive block, I'm only able to select between 0 to 2 channel. However, the FCAN Config block can show 0 to 7 CAN channel.
How do I use CAN transmit and receive on all 8 channels?
