I use MBDT to generate code, compile without error, but I can only receive the can message at the moment of power-on. The attachment is my model and code.
Hardware issues have been eliminated, handwritten code can accept information normally;
I use 9s12zcva192 ,Please help me, I will be very grateful.
Solved! Go to Solution.
The issue has been resolved and it is hereby ending the post. MSCAN send priority is too high and must be lower than Base System Tick Priority
Thank you for letting us and everyone else know the fix to this problem.
