MBD_freemaster problems
haoxue1027
Hello
What is the meaning of  coefficient a=9.5492965964254 in the demo "PMSM_ClosedLoop_mpc5744p"freemaster?
In addition, Whether to use scalar values uniformly in the MBD demo?
Any help will be appreciated.
hao
adriantudor
Hi @haoxue1027 ,
This coefficient represents how many rotations per minute is 1 rad/sec. The reason o using it is due to the method of speed measuring using hall sensors ( Speed_and_Position_Estimator  block).
Adrian
adriantudor
Hi @haoxue1027 ,
Adrian
haoxue1027
Hello,Adrian
Thanks you for replying.
In addition , Is the  a=0.005,Execution Time same meaning?
best regards
hao
adriantudor
Hi @haoxue1027 ,
This coefficient multiplied with "profile_buffer" variable it represents the time base of the timer used by the Profiler block. I think there is a mistake if you found this coefficient 0.005.
As you can see the Unit of this variable is shown as "usec" microsecond. That means the frequency of the timer used by Profiler is 1/0.000000005 = 200Mhz(so many zeros because of usec Unit).
Adrian
haoxue1027
Hello,Adrian
Thank you very much.
It is helpful for me.
best regards
hao
