MBD MPC5744 CAN Receive interrupt does not work
fupeng
Hi all,
   I used MBD mpc5744 to create a can receive model,my trigger function is to make a Led bright. I can receive model send can data, but the can receive interruput does not work.The following is my model.
trigger function model
dumitru-daniel_
Hi fupeng‌,
Have you tried the example shipped with the Model Based Design for MPC5744P ?
The example/demo is doing the exact same thing with what you want and can be found here: {MBDToolbox Install dir}\mbdtbx_MPC574xP\mbdtbx_pnt\Examples\can_model_pnt.mdl
Please give it a try and let us know if this works. If the demo works then most likely there is a configuration issue in your model - and you could use this demo as a starting point.
Hope this will resolve your issue.
dumitru-daniel_
Hi fupeng‌,
fupeng
  This demo can work properly,Thank you very much for your reply!
