How to use Rappid bootloader with S12ZVML-MINIBRD kit ?
Maciek
Contributor V
I've flashed S12ZVM.rbf file into the board (and configured COM port and 'download after build' in model Configuration parameters). When I'm trying to build and download Simulink model into the board - I get the following error message: 'CCP Communication Error. Loss Communicatin with CCP MCU. Please cycle power and try again."
How to slove this problem - I want to check PIL with this kit ?
Does the Rappid bootloader work with UART1 (which is accessible via USB on this board) ?
Maciek
raduivan
Hi Maciek,
   Try to rest the board after writing the rbf, using the reset switch or by removing the power supply.
   Press 'OK' button in less than 5 seconds.
Radu
