Getting License error with MBDT Toolbox
Search instead for
 License Error: -1, Model-Based Design Toolbox License Missing, please go to The Model-Based Design Development Toolbox Web Site to get a free license or request a demo. Provide the following HostID: ec51e3ec
Hello harjitsingh‌,
In order to use our MBDT blocks you need to get a free license form the NXP's website using the HostID mentioned in the error message. To do so, please go to https://nxp.flexnetoperations.com/control/frse/product?entitlementId=231620027&lineNum=1&authContact... this page, select the toolbox you need, read our terms and select the License Keys tabs. Press generate and follow the procedure.
Once you got the file, please go to the Matlab installation toolbox, find the .src folder, and inside it create a lic folder. In that folder put the generated license.
Hope this helps,
Marius
Hello Marius,
1.Here is the serial number of my HOST ID;
2.This is my license;
3.This is my MATLAB installation location;
4.This is where S32K-MBDtoolbox and license are located;
Please help me! Thanks!
Hello @orange_ ,
Can you please rename the extension from .dat to .lic?
Hope this helps,
Marius
Hello Marius,
Thank you for your help.
My problem should appear on the installation path of MATLAB. After modifying the path of MATLAB, the problem has been solved.
Thank you very much for your help!
orange_
Hello Marius,
C:\Users\admin\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx
C:\Program Files\MATLAB\R2018b\toolbox
There are the different folder structure. One for the Matlab installation and another where the MBDT is installed.
I am unable to find the .src folder in both the above folder structure.
Following path has .src folder. Kindly advise where to put the license file.
C:\Program Files\MATLAB\R2018b\src
Hello harjitsingh‌,
According to your provided path, you have to create a folder "lic" directly in the NXP_MBDToolbox_S32K1xx and inside it to put the license.
C:\Users\admin\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\lic
Here is a screenshot from my folder path
Hope this helps,
Marius
