I've managed to install MBD Toolbox for MPC564xL. I can build example models without problems. We have found older TWR-PXS2010 kit with PXS2010 which I know is earlier (before change) name for MPC5643L.
Unfortuantely we don't have easy access to LINFlex_0 on this board. But LINFlex_1 can be accessed via on-board OSBDM Serial Bridge.
So I have a question:
is it possible to use Flash Bootloader (.rbf) for MPC5643L (or for PXS2010 - there is such .rbf in 'Bootloader' directory) with LINFlex_1 as serial communication interface ?
I can't find any info: what peripherals can be (are) used with this bootloader...
Maciek
Solved! Go to Solution.
Hi Maciek,
The RAppID bootloader for MPC5643L MCU was built to support the communication over the LinFlex0 and CAN0.
These configurations are hard-coded inside the bootloader.
I do not know if that helps you - but that's how it was done.
Hi Maciek,
Hi Daniel,
thanks for clarification. It helps.
It's strange but I really can't find reliable information how bootloaders are configured!
Maciek
