FTM Dual Edge Capture error
Search instead for
nicolas_thory
I used a "FTM Dual edge Capture " of the NXM MBDT and after several tests tuning prescale factor It seems that there is a maximum time that can be measured by this function. Could you indicate what is this maximum? WIll a correction be possible , maybe using uint32 in output of this block instead of uint16?
