I want to program the Kinetis MKV10Z64xxx microcontroller using the Motor Control Toolbox for Kinetis V in simulink. In the target list under Target MCU Config i can select only the MKV10Z32xxx and the MKV10Z16xxx series. The MKV1xZ64xx and MKV1xZ128xxx series are not in the list, so can not be programmed.
Question
- Is there another way to select the MKV1xZ64xx and MKV1xZ128xxx series, or is this simply not possible?
- If not, is it planned for the future to support these series?
- If both false, is there a work-around?
Theo
Solved! Go to Solution.
Hi Theo,
Unfortunately, for the moment we do not have an workaround to cover for MKV1xZ64xx and MKV1xZ128xxx devices.
For the next period our focus in mainly on Automotive parts like S32K and MPC series. If we get more feedback like yours then we might change the plans.
++ michaelhaight for awareness.
Hi Theo,
