Hello everyone,
I am currently using MBDT for code gen on S32K144 eval board. I am using the lastest patch of MBDT, also I can generate code succesfully, however I am not able to connect to external mode. I have read thoroughly the posts regarding external mode like: (the path should not have spaces, tick external mode on config parameter on code generation -> interface, etc...) BUT keep getting the same error as follows:
Application BuildInfo does not exist: buildInfo.mat.
Any solutions to this?
Rolando
Hello @mariuslucianand ,
Still unable to connect. Any other solutions? May be good if you can try and share your results here.
Rolando
I have done exactly the steps shown on the link. When I clicked "Build for Monitoring", no problem application compiles and runs on the MCU, however when I click on Control Panel -> Connect I get this error:
Also my configuration is:
So what is the problem?
Rolando
Hello @rolo90 ,
Can you please try the procedure explained in the following thread?
Hope this helps,
Marius
