CCP Communication Error
张三san
I am using MBDToolbox to work on DEVKIT-S12ZVC.
but when Progress MCU,it did not work.
I have flash the S12ZVC.rbf into the DEVKIT-S12ZVC.
zzdh
Hi,my board is same with 张三san.
Just now,I change a rbf file and it works.
Thanks!
zzdh
张三san
Thank you for your reply.
This is my board.
I have connected UART use COM4
dumitru-daniel_
Can you add a picture of the board and see how you have connected the UART  with the board ? There are different UART connector between programming the application and running it.
