Hello community!
Can someone please confirm that the CAN FD master mode example actually works in the S32K146 board?
I configure the system to receive a CAN FD message, when it does, turn on a red LED. This works. Then, send me back a CAN FD message with a fixed ID and turn a blue LED.
The problem occurs when I send a message with a DLC > 8, the length of the message is not received in the CAN monitoring tool, neither does the data of the message, only the ID.
Can I get some help with what might be going wrong here?
Edit: I added a picture that shows the issue.
Kind regards.
