Hello everybody!
I am currently trying to know how much memory of my S32K144 is being used by an application that I made in Simulink.
Looking in the .map file, I find this information:
As I understand, the RAM (m_data) consumption would be of 32 768 B? How is that even possible? Am I reading this the wrong way?
Kind regards,
Juliana
Solved! Go to Solution.
Hello @juliana_rojas30 ,
I think the 'src' is the problem in your path, please open in explorer.
The full path for me is 'C:\AddOnR2019b\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi\bin', but obviously it differs from PC to PC.
Hope this helps,
Marius
If you want to get the size of the generated code, inside our toolbox, please go to this location {Toolbox installation}\src\tools\gcc-6.3-arm32-eabi\bin there is an executable called arm-none-eabi-size.exe
If you run this executable passing as argument the generated elf you will see the following output:
C:\.....\>arm-none-eabi-size.exe generated.elf
text data bss dec hex filename
46884 1272 6104 54260 d3f4 generated.elf
Hope this helps,
Marius
Hello @mariuslucianand ,
Thanks for your reply. I was trying to look for the direction you said inside the project folder I am working on, but I can't find the folder "tools". There's one called "clock" and another one called "power", but no tools. Actually if I put only the direction directly on the path, I get this:
Should I run any command to generate this folder or something?
Thank you!
Kind regards,
Juliana.
Hope this helps,
Marius
It worked perfectly! Thanks for your help!
Kind regards,
Juliana.
