I was facing a license error for Model-Based Design for SPT 2.0/2.5 Toolbox even though I followed all the instructions mentioned in the SPT user guide. Can anyone help me resolve this issue ( Details also attached)
Search instead for
nxf38675
I was trying to install the SPT toolbox for which I downloaded the SPT toolbox from the link:-
http://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=MBDSPT
I also installed the corresponding toolbox in MATLAB and it is also shown in the add-ons in the Home button.
I obtained the license by entering the host ID and ethernet address on the same link and generated the license.dat file.
Now I copied the license.dat file to the installation folder where license folder is available.
I installed Visual Studio 2012 as it was mentioned in SPT User guide as it is a requirement.
After finishing all these steps, I am still getting the following error regarding license file in MATLAB.( Photo attached)
Can you help me to fix this error regarding license file as I performed all the required steps mentioned in user guide?
constantinrazva
Hi nxf38675‌,
You are having some licensing problem - can you please try again to license the product following the instructions from this discussion ? This should do the trick.
Please let me know if you're still having trouble.
Kind regards,
Razvan.
